Odd behavior of my Remote One
I have had my Avant 55 and Remote one for almost 2 years, it has worked perfect until recently, when I changed the batteries.
The remote seem to restart it self, it stops working, the display goes black and then the text Bang Olufsen appears. This can happen 3-5 times within one minute, then it works as shall for a while (days).
Has anyone had the same issue? What was the fix for it?
//Rikard
You need to open the remote and make sure that you have the batteries secured tightly to make a good connection.
Similarly, the magnet in the wall holder is notorious for make the IR-only version lose battery contact.
I think you were right, it must have been something with the power, the same display appears when it is put together.
I removed all pieces, there is only one way to mount the battery holder together, but I also cleaned the connectors. Now it seems to works as i shall - flawless :)
