Ny laser beosound 9000
Hejsa.
Skal ha ny laser i min beosound 9000, nuværende laser hedder vam1205, kan har hørt andre typer også kan passe..
Kan nogen hjælpe mig, med hvilken der kan bruges?
Mvh
Morten
Hi
i hope you can read English.
Ebay cdm-vam 12.4 will be ok :)
and good luck :)
Hi..
Is there no differencen between 12.4 and 12.05?
Best Regards
Morten
VAM 1205 mechanism in BS 9000 have laser inside that is called vam 12.4
it's cheap fix ...not original Philips but...cheap and working fine.
go for it :)
Thanks m8.
Can you give me a link ☺
just check on Eby..com for VAM 12.4
You buy form midle price sellers.
80% of them working well :)
