Hello,
Let me just start by saying this is my first post on the forum as I have just acquired my first bit of B&O kit, so please excuse me if I ask any stupid questions.
I have recently purchased a Beosystem 5000 from ebay, consisting of:
- Beomaster 5000
- Beogram 5005
- Beocord 5000
- Beovox S55's
- MCP 5000
However, this system is far from perfect...
The Beocord is as dead as a dodo, no lights, no movement whatsoever. I have changed the fuse in the plug, but this did not turn out to be the problem. I don't even know where to start looking on this one, I don't play any cassettes, but it would be nice to get the unit working.
The Beogram is what I mainly intend to use the system for, it is complete with an MMC4 cartridge, but the audio output has a horrible distortion. I am aware that I can purchase a replacement cartridge from Soundsmith, or have the original re-tipped by Axel in Germany. Does anyone have any experience in either of these, what do you recommend, and are there any alternatives available?
I have also noticed that the Beogram can tend to have a mind of its own... Sometimes, when I press the stop button, the arm will refuse to lift, thus scraping it across the record!! 😉 Other times, the arm moves into position on the record and then proceeds to raise and lower the arm continually. I have now cured this twice by removing the platter, and manually operating the solenoid that engages the lift/lower gear mechanism.
The 33 / 45 window on the indicator arm is missing, so I am just left with two square LEDs. Is it possible to source a replacement part, or would it be simple to fabricate a replacement?
The Beomaster appears to be in good shape, although I have only tried it through the phono channel, as I have no other working sources. The only issue I have noted is that the "Open" button can be temperamental, and will do nothing unless pressed twice or in a certain place etc.
The Beovox S55's were advertised as having "light foam perishing", but removing the grills revealed that there was in fact no foam left at all! I am currently listening to the system through my home cinema connected to the "Pre Amp" terminals, so I am not in a huge rush to get these speakers repaired. Am I best buying a re-foaming kit and repairing the woofers myself, or buying a replacement driver all together?
I am yet to buy a set of D batteries for the MCP, so cannot comment on the condition of that as of yet.
Any help and advice would be greatly appreciated as I know very little about B&O products, I purchased this system as I have always liked the unusual styling of the Beogram turntables, and the whole system looks pretty sleek over all.
I have tried to upload images of the system, but I can only seem to upload one at a time.
Many thanks in advance,
Lewis.
