That should be an issue for Beocare - must be asked!
Greetings Millemissen
The update is now finished and a quick look at the display reveals no changes. As for the missing stations they have not returned.
I have just sent a request to BeoCare.
Thank you and
Cheers
Hi, I have tried to download the new software with my Beosound 5. But it just says 0% and nothing happens. I tried yesterday evening at 10 pm and let the download progress thru the morning. But still 0%. Is the server with the new software down or does it work fast now? Does anybody know?
Regards
Maybe the update has been downloaded automatically? Check the version#
Hi, I have tried to download the new software with my Beosound 5. But it just says 0% and nothing happens. I tried yesterday evening at 10 pm and let the download progress thru the morning. But still 0%. Is the server with the new software down or does it work fast now? Does anybody know? Regards Martin Beovision 7-55 3D with Bluray, Beolab 5 (sw 3.0), Beolab 3, Beolab 3500, Beo4, Beosound 5, Beomaster 5, Beosound 9000 Mark III (sw 2.4)
I have tried to download the new software over the weekend. But it does not work. The Beosound 5 finds the software but it will not start the downloading. The display just says "Downloading 0%". The percentage does not change from zero.
The software in my Beosound 5 is 6.05. What could be wrong with my BS5, or is it maybe B&O:s server that does not work.
/Martin
Problems addressed
Net radio stations cannot be played or buffer for several minutes
Several drop-outs while playing certain net radio stations
Cover art not shown with FLAC files
Not possible to reduce volume to '0'
BeoLab 3500 - Display always shows CD-128
In option 1 the volume will be raised to default when re-activated from link room
Enters standby without warning during normal use
Inactivity timer turns off other main room products as well
Problems addressed - before 6.0.6!!!
We could use this thread to sum up the problems after 6.0.6 - for posting to the BeoCare.
