I can't upgrade at all though the "online update"
I've tried hard resetting and switching back to DHCP to no avail.
Does anyone have (or know where to get ) a firmware file for anything greater than v1.4.1.20107 they can share?
Thanks!
Michael
Thanks!
Michael
Happy New Year :-)
Same at my system, online Update function on 1.5.4.557 doesn't work !!!
Any hints, tips or tricks available ??
Thanks in Advance :-)
PS: i`m running on 1.5.4.491
Happy new year,
some problems as the others in the thread ....
online update function on BLGW to x.x.557 doesn't work !!
I`m using v1.5.4.491
Offline file available ?? Any hints, tips or tricks ?
Thanks in advance.
I wonder if the new firmware update has anything to do with the new ML driver that seems to be for the BLI. Possibly for better ML integration with the BLI by interfacing a BLGW? I can't find any updated info on this in the FAQ section of Khimo's site. Nor on the Beointegration site.
Hello Jeff,
The update is suggested on the GUI of my BLGW / Tools / Firmware...
Especially the MJPEG stream handling improvements are quite important to me...
Screenshot of my BLGW:
Problem solved :-)
Khimo changed the CA Certificate of the update server,
Backup config / reset to factory default / reboot
(during this the CA Certificate is updated by first contact to update server)
FW Update work sucessfully
import Config and works fine :-)
Thanks for your support :-)
