new firmeware BLGW
I can't upgrade at all though the "online update"
I've tried hard resetting and switching back to DHCP to no avail.
Does anyone have (or know where to get ) a firmware file for anything greater than v1.4.1.20107 they can share?
Thanks!
Michael
BeoLink Gateway | Release Notes
Changes in BLGW SW 1.5.4.557 since previous version 1.5.4.491:
New features
  • None
New & updated drivers
  • BeoLink driver:
    • Implemented several improvements in BNR communication with B&O products.
    • Source selection: Implemented select source by unique id, command that is used by the applications when available.
    • Mybuttons/Profiles: Corrected profile recall to use correct ids, this solves snapshot commands on newer TV's. (Eclipse, Harmony)
  • Philips Hue driver:
    • Fixed bug in import resources procedure.
Quality improvements
  • Android TV web panel: There was a bug in the widget list for TV, that was ending in some columns not being shown.
  • User macro handling: If a user is removed the macros are still handled as user editable macros.
  • IP Cameras: Changes MJPEG stream handling so they are always reconnected every 25s.
  • Improves startup behavior to ensure all processes are started up and running corretly at boot.
  • Optimized several processes which could lead to unstable behavior or crash conditions.
Happy New Year :-)
Same at my system, online Update function on 1.5.4.557 doesn't work !!!
Any hints, tips or tricks available  ??
Thanks in Advance :-)
PS: i`m running on 1.5.4.491
Happy new year,
some problems as the others in the thread ....
online update function on BLGW to x.x.557 doesn't work !!
I`m using v1.5.4.491
Offline file available ?? Any hints, tips or tricks ?
Thanks in advance.
I wonder if the new firmware update has anything to do with the new ML driver that seems to be for the BLI. Possibly for better ML integration with the BLI by interfacing a BLGW? I can't find any updated info on this in the FAQ section of Khimo's site. Nor on the Beointegration site.
Hello Jeff,
The update is suggested on the GUI of my BLGW / Tools / Firmware...
Especially the MJPEG stream handling improvements are quite important to me...
Screenshot of my BLGW:
Online update
Last time checked         Jan 5, 2020 9:36:44 PM
Latest online version     v1.5.4.557
Current Version             v1.5.4.491
New features
  • None
  • BeoLink driver:
Problem solved :-)
Khimo changed the CA Certificate of the update server,
Backup config / reset to factory default / reboot
(during this the CA Certificate is updated by first contact to update server)
FW Update work sucessfully
import Config and works fine :-)
Thanks for your support :-)
