Very nice - but you need the speaker stands as the bass port is on the underside of the speaker, The Beomaster 3000 is not a bad amplifier and will drive the MS150s to good volumes.
Thanks Peter, i know.
It's hard to get those stands here but meanwhile I had already cut a 5" hole for the bass ports, also the feet are adjustable so I can tilt back the base a little.
The Beomaster 3000 is doing a fine job with the MS150's so I don't feel the need for more power.
Apologies for my terrible english.
Regards.
Here something about M150 stand, original square tube dimension is 20 x 30 mm, here in Mex. 3/4" x 1 1/4" is easier to get
Thanks Søren, that will be a fun project sometime this year 👍
Saludos.
Welcome to the forum!
Nice stuff you got!
Nice stuff you got!
Thanks, Anders!
The equipment in your avatar looks very nice.
Regards.
