My Beocenter 7002 is not well
Everytime I push the volume past 4 on my Beocenter 7002 after about 5-10 seconds it goes into standby.  It does this on all inputs and even tried switching to speakers B but it still did it.  Can anyone help this ageing rock chick whose hearing is going and volume four is no longer loud enough!!!🙂
Lizzy x
Hi Lizzy
Anzi... Ciao Lizzy, da un Umbro/Pugliese 😁
Proseguo in inglese per correttezza.
The problem could be in the loudspeakers or in the loudspeakers connections.
Try to disconnect the loudspeakers and power on the unit and set the voulme over 4, does it go in std-by again?
IF YES, there could be a problem in the ampli section.
IF NOT the problem is in the speakers or speakers connections.
If you need help ask here or send me a message
ciao ciao
Eugenio
Ciao Anzi
Mio Italiano e cattivo!
So I will reply in Italian.  I am in the UK at the moment but return to Alberobello in November for the olive harvest.
Thank you for the suggestion which I will try when I am there.  In fact someone else suggested similar and recommended unplugging the speakers and plug in headphones - if this solves the problem then it is the speakers/connections - if not I need an engineer to look at it.
If I need an engineer, do you know of anyone in southern Italy?
ciao, ciao
Lizzy
In the southern not but in the middle yes 👍
