Beosince98 wrote:
Beautiful and easy solution to the problem. I highly recommend this solution as you keep within the ecosystem and remain remote functionality.
Yes, and actually no!
All that happens, is that you (with the command TV) can open a port in the ML ecosystem in order to send any audio in there.
You highly rely on the ChromCast device (or any other choosen audio device) and on the apps, that you need for the playback.
Using a NL/ML converter in order to feed the sources of e.g. a BS Core is different.
You will be able to use the sources/possibilities, that a NL-based device brings to the mix in the ML chain as well as the sources of the ML chain/BS5 via the Core. Please also think future usecases.....you might get another NL device sooner or later. And you can ‘map’ these sources to different commands on the Beo4 for an easier access to e.g. a playlist or a netradio favourite list.
However, if what a ChromeCast device can add, is sufficient for you, do use the 1611 suggestion - it is relatively simple to do!
I just want you to know the possibilities, that you have....in order to make the right choices.
