i’m not a tech savy and managed to make it work. What you need is to add a masterlink plug to your system if you don’t have one free. Thats the difficult part. You can get one installed by a technicien or find a masterlink multiplug and add a new cable with plugs on both sides, or split a cable yourself and do the wiring with a junction box.
Then you add to this plug the converter, and power it up. It will autoconfigure itself and see your beomaster as a master. You will plug the chromecast or sonos or wathever you want as a secondary source in the converter aux in. The converter can also act a master but you need to change the option on the beomaster 5 to slave, in this case when you press on play on an ir eye what is played on the converter will be played through your system directly.
All you need to do is press tv on the beo4 instead of radio or cd so pretty integrated and pilot your music through your chromecast via phone or tablet, you can change the volume through the phone. So 2 steps instead of one but still acceptable.
works 99,99% of the time for me depending on my wifi.
easy solution and cheap, wished my b&o technicien would have proposed this from start would have avoid to buy a beomaster 5, but little regrets as i do love it to listen to CDs and looks good in my living room.
i have an android tv plugged in also the converter, plays spotify or can play video clips via youtube or tv channel works with voice through google home or phone. Unfortunetly my other android tvs (sony) are not linked and can’t play video clips in multiroom but maybe google will offer this functionality one day.
location isn’t so important as all this works through wifi or masterlink network so 0 cables going around all integrated in the walls.
one room was not linked to the network so i’m using a beolink wireless, works in the setup but system itself isn’t super reliable only works 75% of the time, will get this room cabled asap.
bottom line, nothing is better than cabling for sound quality and reliability, and when wifi is down you can still listen to a cd.
sonos is cheap but love the looks of my bang speakers, ir eyes and essence remote, don’t need to walk around with a remote as i can turn the music on in any room independently.
