Greetings, I'm new to the world of B&0 and have acquired a few items, including a Beomaster 5500 along with it's MCP 5500.
I am having the classic "rotary encoder" issue. I have searched the forum, and found many answers, however I am still unsure as the the issue, so I am asking here.
1: MCP communicates with the Beomaster, all buttons and functions work except for the rotary dial.
Symptom:
The dial has no effect on the Beomaster. When using the dial, the display is blank, the MCP does not "wake up" Reading other posts on this subject lead me to believe the switch was bad.
As a result, I have done the following.:
Tested the switch for continuity, tested the wiring from the board to the switch, tested the connector on the board.
In short, the switch seems to be working fine, I have re-soldered all switch connections.I have tested the switch, manually activating the poles, I have even gone so far as to temporarily bypass the switch and jump the connection, yet the display still does not activate.
As far as I understand it, any movement of the dial, will cause the switch to activate. since it appears my switch is good, and the display does not respond, I assume my problem lies further down.
Also, I have not found a safe way of removing the PCB, I have removed 2 screws, yet it is firmly attached and I do not want to break anything.
Any and all help would be appreciated.
Thank you in advance
Michael
