masterlink to rca cable for beolab 2000
need to link my beolab 2000 to my bc9500 , the units are next to each other so the controlls on the 2000 won't be used , just need to find an input for the 2 channels coming from the powerlink. Does this sound workable  ? surely there's a way on to the amplier of the 2000 without using the masterlink ? has anyone seen or heard of such a cable or know the schematics of the amp? i am quite  competant at electronics and dont mind making cables/soldering terminals but am unfamiliar with the masterlink system - any help would be great - cheers
just had a quick mooch on ebay and found a converter for £28 delivered , i thought for that price i might aswell !  still though , an input for a 3.5mm jack/rca to a link speaker would be handy as you could you a link speaker a a stand alone unit for any source - that is if the amplifier on the link speaker would take it .
You might be able to connect the Beolink Convertor to the BL2000 (stand alone) and get an RCA to powerlink cable and see if that works.
Stoobie
Exeter,
Devon,
UK
ive got a pl to 3.5mm jack - i'll give it a go when the converter comes - sounds promising
Any updates on this yet? I'm interested in doing the same thing!
Any news on this?
No one?
