Masterlink Gateway and Beolink Gateway integration Home Assistant
Hi Baaz
I figured out what's wrong,
You have set the NMusic source as CD.
I modified the plug to make it work in this configuration as well.
Download the new version from my github repository.
Let me know if it works.
Lele
It works! 🙂
Thank You all!
I really hope this helps for other installations as well.
Now I'll add the other products and add functions.
Take care
Baaz
Hi...
I have updated my version of the plugin.
I would be happy if someone installed it and reported any bugs.
you can download the plugin from this link link.
Thank you
