So Baaz is the sequence working for you?
The logs show that the turn on / turn off commands are sent correctly and that they activate the N.RADIO source.
Let me know!
Let me know!
Hi Giovanni,
no, default card only turns on once, second time no response.
So I'm enclosing a new log with four commands - default card on / off / on and then mini-media-player on.
On the third command (default card) no response on the fourth command radio button on the mini-media-player
the radio goes on.
Presume it makes no difference but I've installed the home assistant on a Raspberry PI instead of the virtual machine on my MAC.
Baaz
Hi there
I think I found the issue. You configured Radio and CD as sources. But in reality, when the device turns on with Radio, the actual source turned on is N.Radio. The second time, when the plugin tries to turn on, it looks for N.Radio which was the previously reported source, but it does not find it in the source list configured (which is only Radio and CD) so it doesn't do anything.
Try to fix the configuration in the yaml by replacing "Radio" with "N.Radio" and see if it works.
Also I made a few bug fixes so try re-installing from the mlgw repository.
Giovanni
Hi Giovanni,
I'm afraid no success. When I put N.Radio as default source and as a source it does send a command.
I narrowed it down even further and removed radio, leaving only cd left, same issue start at first but not the second
time the MMP still works through it's drop down list with sources. The MMP did not add N.Radio when changed in the yaml-file.
I think I understand the problem in solving this issue, the error when nothing happens doesn't give any records in the log.
Could it have something to do with the source menu under roles in the BM5? I've got:
NMUSIC set to CD
N.RADIO set to RADIO
Baaz
Hi Baaz.
Ok, I added some more logging and let's see if we can get to the bottom of it. Do you mind re-installing from github and then running through the source selection again?
Thank you for the help in debugging this!
Giovanni
Giovanni,
no problem, my pleasure:) Installed new version, same fault. Enclosing new log
with only BM5 and CD on the BLGW.
/Baaz
Yeah, here is the problem: your 'CD' selection actually activates N.MUSIC on the BS5. The BS5 tells the plugin NMusic is on. The second time when you try to turn on the device, it remembers that the last source was N.MUSIC. But, because N.MUSIC is not included in the sources in your configuration file, it throws an error saying that it is not an available source.
Try adding N.MUSIC as a source in the configuration file.
Alternatively, use the automatic configuration (not configuration.yaml) from the integrations panel and see if that works better.
G.
Giovanni,
I think You're close now, It did not succeed totally but I get a log entry on each command.
I've added N.MUSIC in the BLGW sources and added the same in the yaml-file.
automatic configuration: speakers turns on but not BM5
Yaml-file: 1st on CD starts, 2nd time same as above, speakers turns on but not BM5
All these were using the default card, using the MMP source CD, music starts,
using source N.MUSIC again same as above - speakers turns on BM5 not.
Baaz
@ Abakus2007.
I modified Giovanni's plug-in. it is optimized for my setup (you can see it in previous posts).
If you want to try it, you can download it here: link
Zeus_72 & Giovanni,
this one works!!!
Thank You!!!
Giovanni I'm enclosing the log from Zeus_72s version, maybe that could be helpful.
I'll start adding new products and sources and keep my fingers crossed it will work.
Thanks again all
Baaz
