Masterlink Gateway and Beolink Gateway integration Home Assistant
Giovannu,
here we go, made 2 versions; 1st with added mlgw config in configuration.yaml 2nd with autoconfig only Your logger:
Baaz
2nd file.
Sorry Giovanni,
pls disregard my files, I've been playing with the blgw and added things, I'll strip it and get back with Beomaster 5 only and cd/radio sources.
Baaz
Sorry Giovanni,
I've changed the blgw since last time, here is an errorautoconfig with only Beomaster 5 and cd/radio
Baaz
and the 2nd file
Hi Baaz
So I looked at your error logs. In the first one (manual), you are configuring the plugin twice, probably manually and automatically, so you should remove the automatic integration configuration.
I am not sure what is causing the out of bounds error. It looks like the configuration file may be mistyped - the "available_sources" config item does not get through to the plugin. Did you check that spacing is correct in the yaml?
In the second one, the problem you are facing is something I haven't yet figured out. When the audiomaster starts an own source , it doesn't tell the ML bus that is happening, so we cannot detect it in the plugin. Unfortunately, we can only detect reliably when a speaker turns on to a specific source.
Let's try to debug issue #1.. can you remove the autoconfig and only keep the yaml configuration and resend me the logs?
giac
Hi Giovanni,
You'll have to excuse my ignorance, when You say remove the automatic configuration would that be in the config_flow.py?
Sorry
Baaz
No just Delete the mlgw from the "Integrations" configuration of home assistant. You want either that one or the configuration.yaml, but not both.
giac
Aha, my programming skills...
Progress! now it will start, I have my two resources and can shift between these. Buttons pause/play and volume still not working.
When I turn it off i won't start again and when I restart the homeassistant server my two beolab 8000 connected to the audiomaster
turns on Beomaster 5 does not.
enclosing three files
Baaz
2nd file
