Here I am with the required log.
Here are the actions I performed while recording the log.
19:20 With the system completely off, using the beo4 remote control, I turn on the BV7 by calling up the DTV (local source).
The BeoVision7 (VideoMaster) switches on and transmits the DTV channel. The interface lovelace does not show any B&O devices turned on.
19.25 With beo4 I change channel on the tv (ch.1)
Login to view image
19:30 With the remote control I change source from DTV to DVD (local sources)
Nothing happens on the interface lovelace
19:35 Using Beo4 I turn off the BV7. The whole system shuts down.
19:40 Using Beo4 I turn on bv10 (VideoSlave) by calling up the TV (local source).
The BeoVision10 switches on and transmits the TV channel. The lovelace interface does not show any B&O devices turned on.
19:45 With remote change channel on the tv (ch.1)
19:50 With BV7 I change source from TV to DVD (from local source to VideoMaster source)
The beovision 7 turns on with the black screen and at the same time starts the DVD.
Home assistant shows the bv10 switched on with DVD source.
Login to view image
19:55 While the BV10 is on, I turn on the BL2000 through its "RADIO" button.
The BL 2000 (Audio Slave) turns on and plays the RADIO source (AudioMaster source)
The BV10 continues to play the DVD (both audio and video)
Home assistant shows shows the BL2000 and BV10 switched on and playing the radio source.
Login to view image
Login to view image
20:00 I position myself in front of the BL10 and change chapter / track of the DVD with the remote control.
The BV10 skips to the next scene and continues to play the video and audio of the DVD
The BL2000 continues to play the radio.
Home assistant still shows "Radio" as source for both devices.
20:05 Through the Home assistant interface I change the BL2000 source from Radio to DVD (from AudioMaster sorce to VideoMaster source)
Both the BL2000 and the BV10 reproduce the audio of the DVD. Logically the BV10 also plays the video.
Lovelace shows "DVD" as the source for both devices.
Login to view image
Login to view image
20:10 Through the Home assistant interface I turn off the bl2000.
Lovelace only shows BV10 active
Login to view image
20:15 Using the beo4 I turn off the BeoVision10. The whole system shuts down.
I hope all of this will help you.
One thing I noticed when viewing the log is that there is a payload type (0X08) which should indicate if the audio_bus of the masterlink cable is transmitting an audio stream. (The audio stream can be from either an Audiomaster or a VideoMaster).
I saw 3 values for the subtype:
If the value is equal to 0X01 then it is a status request.
If the value is 0X04 then it is an answer whose meaning is "the bus is not occupied by an audio stream"
If the value is 0X06 then it is a response with the payload_len: 4 which means "the bus is occupied by an audio stream". The last Byte will be the source that occupies the bus.
There are also two other payload types 0X07 and 0X1C but I don't know what they mean.
I am waiting for your reply.
