LUA variables on BLGW
Hi everyone,
I’m programming IF ELSE statements on my BLGW and want to use some variables to make some commands work. Apparently unless defined as local the variable are global by default. However I don’t seem to be able to share variables amongst macros. Anyone any clues??
Hi, do you get the if else-statement working in a macro? I tried it several times for programming brightness-depending scenes. But without success.
I want to switch the mode in blgw if brightness is higher than xxx
Do you have an example?
Closest I’ve been able to do is use state updates from the panel
IE volume is 30.. closed drapes and blinds
