linking my active penta speakers with a turntable
Hi guys.
a little advice if possible.
I have a pair of active beolab Penta speakers which i have previously run from a beocenter 9000 (both circa 1989).
My question may be somewhat naive - but i am wondering if i can purchase a turntable that i can plug directly into my speakers (as they have their own amps). i no longer use the beocenter 9000.
If so can anybody advise on a compatible turntable this would be a major help before i try to buy one. My current speaker leads have 4 pins, one flat and three "needle" shaped.
Stoobie is quite correct, the Penta only has power amplifiers, so you would need a preamplifier, unless you can find a turntable with built-in preamp with volume control. Also the displays in the Penta's would not work.
Pete
