Greetings
My company was hired to revamp an older home system (2008). The home has a very elaborate B&O Setup throughout. We are experiencing control issues between zones. i.e. Turn on BeoSound 9000 located in Great Room (Paired with Beolab5s) and the Theatre's rear Beolab5s turn on. Volume up in great room turns on rear deck Beolink amp. Etc etc etc. I believe the issues are all related to option programming and this is where I'm having difficulty. I attempted to set these but I just can't get it right. The goal is to have all the equipment (zones) controlled independently of one another but to all share the BeoSound9000 because this is where audio input from the AV receiver is coming in. Everything (each zone) has it's own IR flasher for a third party control system.
What do I need to sent the V/L/A Options to in each zone to accomplish this?
Rough breakdown of what's there - all connected together via ML Distributors (4 I have found so far)
*Please forgive me if I get some part numbers wrong
- BeoSound 9000 (with IR from RTI RP6, aux input from receiver and Masterlink ML Distributor)
- BeoLab 5 (hooked up to BeoSound 9000 via Powerlink)
- Beolink Amp (Controlled via IR and connected to Wet Bar ML Distributor)
- BeoSystem3 (Hooked up to ML Distributor)
- Beovision4 65? ( I think, haven’t pulled it off the wall)
- (4) Beolab5 (Powerlink to BeoSystem3)
- BeoLab 7-2 (I think, haven’t pulled it off the wall, Powerlink to BeoSystem3)
Dining - BeoSound 3500
Kitchen - BeoSound 3500
- (4) Beolink Amps
- (4) Beolink Active
- Beolab 8000
- (2) Beolink Amps
- (2) Beolink Active
- Beolink Amp
- Beolink Active
- Beolab 8000
- Beovision4 55?
- BeoLab9 (Hooked up to TV)
- Beolab 4000?
- Probably a Beolink Active
Thanks!!!
JF
