Is there an intermediate software version, which has no LAMP entry due to the software bug regarding LAMP?
Is the LAMP entry PRODUCT specific? Do i have to add e.g the BEO4 AV product?
Ralf, I pointed to the other thread because version 1.0.1452 I showed does NOT have any LAMP entries under LIGHTING, that was my point..
You should ask the thread initiator to use my instructions in the other thread to check the version of his software, both the APP & other software
