My expectation is that 99% of sound bar customers will have zero external speakers, let alone 8.
I think a mains out connection from the tv itself is probably more useful to a sound bar customers than wisa.
Sure, that is possible - with a modern HDMI/ARC solution.
But that would mean that the decoding (of he Dolby Atmos stream) would have to take place in the soundbar.
However, the new thing about the coming LG tv’s is, that they can do the decoding (up to 8 channels) internally and output these......
....but only wireless (using WiSA).
That is the whole point of the WiSA Ready specs of these tv’s.
A direct cabled solution will not be possible, if you want to benefit from Dolby Atmos there.
You won’t have the opportunity to use cabled speakers or a mix of cabled and wireless there.
Neither to a 7.1.2 soundbar nor to seperate, external (B&O or maybe LG) active speakers in a 7.1.2 configuration.
NB. for a Dolby Atmos soundbar (including a sub) you will always need the 8 possible connections, when used with these coming LG tv’s.
You can do with less - but that won’t give you any Atmos.
As you wish, I've lost interest. You must have a PhD in Attrition! I can only think that you must have emptied hundreds of bars in your time.
