I have a pair extra. Let me know if you're interested.
What are you asking for them?
The magnet, core that sits inside and the top plate are all glued together during manufacture.....the glue gets tired over the years and fails, follow the post and carefully pull the magnet from the frame.....
Thanks Craig I had a little play over the weekend and managed to separate everything. Will be cleaning them up today and re-gluing following your thread. Without a Jig I'm racking my brain how to align the centre cone accurately.
I have tried a couple of different methods....none have worked as well as the jig method, its not difficult to make one from a section of plastic pipe ;¬) I can post a few pics if you like?
Craig
