Hello all,
I connected an LC2 to the ceiling lamp and it worked fine for a few days. Then it stopped working. I suspect that it’s caused by the ceiling outlet, which has some issues that need to be checked by an electrician.
But I was hoping that I could fix the LC2 myself. I took it apart and there are no signs of burns or capacitor leakage. I connected the mains and a standard 25 watt lamp. When I touched the outgoing cable connection screw of the LC2, with a voltage meter, the voltage meter did not light up.
When I disconnected the lamp and then touched the outgoing cable connection screw, the voltage meter did light up. It seem that some power goes through when a lamp is not connected, yet this disappears when a lamp is connected. Would any member have an idea what could be wrong?
Thank you very much in advance for your help!
