Is it possible to change the connector for the internal speakers of Beomaster 900K?
Trying to disconnect the internal speakers from the plug (during some other repair) have somehow wrecked the internal connector, see picture.
The connector seems to be a five pin 180 degree DIN. But I can't see how to change it? It is not fastened by screws as I can see.
Any ideas?
Thanks.
Well, those look like plastic rivets from a distance,  Possibly metal, so the likely solution in either case is to drill them out using a small eg. 1mm drill until the body of the rivet has been removed.   A DIN chassis socket should be easy to source and then a couple of short bolts should complete the job.
