Hi all
I have a very strange problem with the IR sensor on my BS5. Sometimes it works as it should but sometimes it does not work at all and sometimes it works for a short while and stops in the middle of me raising the volume (example). It is the same when I try to turn the BS5 on and/or change source. Sometimes it works and sometimes it does not. I have tried in the middle of the day (lot of sunlight) and in the evening - same problem. I have cut the power and rebooted the BM5 - same problem. I have taken out all the cables from the BM5 and put them back again - same problem.
I do not know if there is something I haven´t tried - can anyone help out?
//Erik F
