I can also confirm smooth and fast performance of two HS110 connected to BLGW - much nicer than using native Kasa application. The only difficulty I had was to find out the IP address of the plugs and make it fixed (by settings on a router). As usual, some setup pictures (and text in Russian) are
Install and use external drivers for BLGW
hi aleksei!
next step: use virtual buttons with status led. then with two additionally macros you can illustrate the current status of the tp-link.
beoandy
Hello Beohut,
i`m currently struggling with the open weather API and my macros.
You described, that you hav a macro up and running. Can you send
me a Screenshot or the macro it self to understand ??
Thanks in Advance,
Manuel
Hello Beohut,
mail successfully received, thanks a lot :-)
