Hello Schletti82,
Thank you for getting in touch, welcome news indeed. Would you consider selling the relay spring to me?
Regards, Carl
Hello Schletti82,
Regards, Carl
Sure, but I think the shipping costs will be higher than the price for the spring.
i life in Munich (Germany) but of course I will send it to you
Thank you. I’m planning to visit Munich next year but we won’t wait till then (smile). Yes shipping costs can be high but I didn't want to be presumptuous on how much you wanted for the spring, plus I’m not sure what the shipping costs would be to the UK. I’ve noticed most people prefer to discuss these matters directly so would you be happy to do that. If yes then my email is cralt@me.com.
Rgds Carl
Hi all, quick update - unfortunately the spring offered above was from a different deck with different internals.
So I will proceed with trying to make a spring.
If in the meantime an original spring is found and offered then great.
Rgds, Carl
Finally!!!!
Hi All,
Well done!
"does it matter what the wattage of the bulb is?"
No. But the type of bulb matters. Use a conventional bulb if possible.
Hi Martin,
Found a conventional bulb (surprised I still had one). Checked platter speed again and was able to adjust to the correct speed via the side wheel.
Many thanks, Carl
Neat job Carl!
I'll know where to come the next time one of these springs fly's past my ear and disappears?
You were lucky with the motor too,usually these need some tlc as the bearings dry out causing low t/t speed.
Load's of threads here of course relating to that,if you need to do it at some stage!
Nick
Hi Nick,
Thank you, yes it was fiddly to do but I'm happy with the end result. Sods law says I will now find the original spring, but it hasn't shown itself yet.
I have plenty of surplus sprung wire which I will keep in case someone here needs any.
I did do the motor bearings for the reasons you give. I was a complete newbie and it was my first job. I was fortunate in receiving lots of help from Martin (Dillen) and others. In fact I took the motor apart twice and feel I could now do it in my sleep lol.
I also added a new belt and LIFT button assembly courtesy of Martin (my belt had stretched and my assembly had broken).
It's been an interesting and enjoyable project, especially being able to overcome problems which at first seemed beyond my capabilities.
It's also been a very time consuming project (learning as you go always is), and quite costly in terms of materials/items needed, but I'm never one to give up - plus the Beogram deserved it! It really is in wonderful condition, cosmetically and now, mechanically.
Thanks again for your help Nick, regards, Carl
