Hello
I am reparing an Beomaster 700 with not so good fm reception. From what I can read on former posts on the beomaster 700 and 900, replacing the two IF transistors should do the the trick. The only problem is that I cant figure out what that is. I search on different electronic component suppliers (in Denmark), but cant find anything called this.
Do they go under another name?
