I got lucky with my newly-acquired BM6000 4 ch., except........
When I paid for this Beomaster 6000 4-channel unit, I knew it was chancy. But I'm not complaining: it's useable as is and all those Quadraphonic LPs will make for a delightful winter. But there are a few things that I'm hoping I can make better. I hope it's okay to make a list in hopes I can get your help.
As far as I can tell, everything WORKS!! Speaker outputs all work, all the buttons work, radio sounds good. I haven't plugged anything into any of the inputs, but all outputs are working, even the headphone jacks. (I bought a pair of quad headphones that need some wires re-soldered. I want to replace the Radio Shack plugs with a nicer pair, preferably longer so that they're easier to plug into the hidden jacks.)
1 - The entire LEFT side of the panel does not light up. Right side is OK. I will guess that indicates a power delivery problem to the left side. I haven't opened up the 6000 yet, so I don't know where to look yet.
2 - The FM dial lighting is weak. I will investigate the various postings of Beolover, et al.
3 - One of the tuning arrows doesn't light at all. The green "stereo" light is very dim. I think I can handle replacing all three incandescents with LEDs. I say this with all the courage of a soldier who has not yet seen the battlefield.
4 - I find that all the buttons seem fairly hard to push. I recall reading stuff about the 6000 having light touchswitches. I don't have a lot of experience with body-conductance, etc., so I hope someone can point me in the right direction on this.
5 - My Beomaster 6000, as well as the Beogram 6000 I purchased with it, has a white plinth which really doesn't go with the cabinetry in my living room. Are trades acceptable for posting in the "for sale" section on this fine website? I have a BG4002 that I can swap bases with the white BG6000. Until I hear otherwise, I will presume the white trim could be swapped off of my Beomaster 6000 as well.
Any thoughts, help, suggestions, will be greatly appreciated.
JackM
Either bad spelling, or bad typing ---- in no. 5 it should be a white "plynth" I want to trade for rosewood.
JackM
Er... no! Plinth is the correct spelling.
Thank, Jacques, at least one question solved.
However, things have taken a turn for the worse since my original post. Now, it doesn't power up at all. I will open it up this weekend, with fingers crossed and hopes diminished.
JackM
A white Beomaster 6000 is an object of desire. Should you want another colour, please find another one, don’t peel off the white veneer!
Good luck with the restoration.
You mean someone would actually do that???
No, I'm looking to trade my white trim or case to get rosewood. Although, since my unit suddenly doesn't power up at all, this may be a moot point. I should have time later this week to open it up and try to coax it back to life.
JackM
Sorry - Mr. Impatience hit the enter button twice.
jack
Update, of sorts -
I have opened it up and found nothing that looks wrong. Surprisingly clean inside for its age. Nothing looks out of place, tampered with, replaced, upgraded or ever even touched, although there is a tag on the outside of the bottom indicating it received some service in the 1980s. From my readings, it is an "early" 6000 owing to the fact that the "stereo" light is green, not red. I've been dancing around this forum, looking for the name of the B&O dealer in Toronto. Anyone know if they still exist and have a "service department"?
Also, in case anyone has been dying to have their BM and BG 6000s in white, I'd be happy to sell or swap the white plinth of either or both of my units.
Belated Happy New Year to all.
Jack
Hi Jack. Lucky you, I have always wanted a BM6000. The 6000 quad does not have capacitive switches like later products - you're bending those metal tabs and moving a switch underneath. Same as the beograms. Maybe what's underneath has oxidized over the years.
In Toronto we used to have a great B&O service place called All In One electronics but they closed up, retired I suppose. You can get in touch with the company store at https://beotoronto.com/  and maybe they can direct you to someone.
Ryan wrote:
The 6000 quad does not have capacitive switches like later products ...
Capacitive switches - what's that?
And which later products have them?
