Hue motion sensor
Aussie Michael wrote:
Thanks ed.
I also see they have the white ambiance. I picked up one of those for the bedroom yesterday.
I want one of those too 😉
Hey everyone - do we know if the Hue Sensor can be used as an event on the BLGW?
Chris Hassell wrote:
Hey everyone - do we know if the Hue Sensor can be used as an event on the BLGW? BV11-46, Beoplay A2, H3 ANC, Beo 4, Beoplay S8, Beosound Essence MkII
Or as a trigger?
Hi everyone,
Almost two years ago there was this thread about using the Philips Hue Motion Sensor as a trigger/event for the BLGW.
Any news about it?
If it works, I could integrate it in my KNX-system and have a non-KNX motion detection system. If not, is there another third party motion detection system which works fine with the BLGW? I don't want a KNX-sensor, because of the programming my KNX-system.
Gr. BeoHut
BeoHut wrote:
Hi everyone,
Any news about it?
Gr. BeoHut
I use the RadioRa2 occupancy/vacancy sensors as triggers. They work great. In fact, I find them to be more accurate and reliable than the Hue sensor. I use them in the bathrooms to trigger Philips Hue lights on/off in macros. The sensors themselves are inexpensive and very easy to setup. However, you must buy the RadioRa2 bridge.
