Hello,
I recently get a Beocenter 1800, in bad condition.
I intend to rescue it, but do not know how open the unit and to remove the turntable
Can someone help ?
TKS
Hello,
Can someone help ?
TKS
Losen two screws at the back where the cooling fins are. From below and up (Rear part of Beocenter over the edge of a table to access with a screwdriver).
Then lift up the back of the turntable section just enough to clear the rear edge of the radio chassis, pull it backwards a little to free it
from under the front rail, raise it up, undo the signal plug and the motor wires and lift it off completely.
Many thanks Martin.
