How to connect Beolab 7.2 center speaker with my Vizio TV
Hi
Sorry for not explaining very well! My cable connects to the headphone socket of the non B&O tv and adds a trigger signal to activate the speaker.  Hence, the speaker thinks that it is connected to a B&O tv.
Kind regards, Steve.
Steve,
Do I need any other cables besides the ones I ordered from you to make the speaker work?
Thank you
Hi Sam,
Yes, you do need a mains power cord for the speaker as well, like this one (US version shown in link):
Hi Steve,
Would you happen to know if it’s possible to connect a BeoLab 7.2 to the headphone jack on a LG CX TV and also be able to use other BeoLabs connected via Wisa at the same time.  Will the TV be able to do this?
I am thinking to replace my Avant with an LG CX but use my existing BeoLabs.
Many thanks,
Suneet
Hi Suneet,
I am sorry but I don't think this is possible.  If you want to use more than two speakers you will need an AV receiver with pre-out sockets, as the TV only produces stereo sound.
Please let me know the full list of speakers that you wish to connect?  I can then advise on the options for wired connection (sorry I don't know about WiSA, as I just make wires!)
