I have just got hands on a pair of old Beovox speakers. Unfortunately they came with no speaker plug attached to the cable. The speakers have to be connected to a Beomaster 4000.
I remember from my younger days I were connecting a 1.5 Volt battery to the cable, and if the speaker were moving forward, I should connect the wire from the plus-pole to the ... pin. Well, I can’t remember.
So question is, how do I correctly connect the two wires to the two pins in a DIN plug. How to figure out, which wire go to the round pin and which to the squared pin? Or plus and minus?
Regrads
Nis
