I recently acquired an SC17 and the plan is to use it for TV and stereo equipment.
Can't find any old manuals or catalogs so far on max weight or similar. Afaik it was made for to fit the Beomaster 1600/1700 (~ 8 kg) and the Beocord 1700 (5 kg) on the top shelf and the Beogram 1600 (6 kg) plus lots of LPs (4 kg ?) on the bottom shelf.
The TV I plan to put on the top shelf is about 18 kg with stand, so a little bit more than the original system. The amp and stuff for bottom shelf would be maybe 15 kg.
So how sturdy are these things? The thing holding me back is that the top shelf has no support «midway», it's just «hovering» all the way over the bottom shelf. Then again, B&O did make good quality cabinets.
Any thoughts?
(Picture from Beoworld)
