Horizon as stand-alone music system
Yes - but please notice that there are two ways of doing so:
1: connected
2: integrated
The first one is, when you have speakers with the product.
The second one is, when it uses the speakers of the tv only.
P.S. If you have the Essence unused now, I’d advice you to use it integrated with the BV.
You can hide it away somewhere - as long as it is on the same network....preferably wired.
it's already on the network, i'll switch it on and integrate it with the BV14.
I might as well move it in the same room as the TV, and i can always run it with wires as i have a full complement of wires in the wall for this set up
Don’t mean to hijack your thread PK but I believe that these findings also help you and are similar to what you may find
However I can’t play something on the essence and it automatically plays on the 14 from the app which I was hoping
I have to use the app and play something on the essence and then add the 14 in a multi room setup
Have to think how I can play something on the essence and it starts up the 14 automatically and starts playing using the TV speakers.
Been trying to tell you that the option ‘integrated setup’.....check that box 🤪
is intended for a setup, where e.g. the Essence uses the speakers of the BV.
You’ll see, that it then will turn on the BV, when you play TuneIn, Deezer...
i think an integrated essence/core would solve the problem just like you showed Millemissen. But it is a rather expensive solution... The multiroom solution works pretty well so i don't think it's worth while buying an additional essence/core. But a second hand Moment might just be :) I have seen these on the second hand marked for half the stickerprice.
Aussie Michael; go ahead, hijack my thread 🙂 I believe a lot of good solutions are coming from this! btw, nice BV14! love the fret on those!
