I've "fallen in love" with the look of vintage B&O equipment and had kind of decided on a Beocenter 7000 series and S45 speakers. Source is LPs. But I've been thinking: maybe I can get better audio (get close to high end maybe?) with separate LP player and amp? I prefer the look with wood panels. Any recommendations? And since Beocenter 7000 was mentioned; are there any differences, sound wise, between 7000, 7002 and 7007? Speaker selection is firm on S45s I think.
High end LP sound?
The Beocenter 7000/7002 has a fine record player with a MMC 20 EN Stylus elliptical naked diamond Pickup. Well - maybe the pickup need a replacement. Try search on Google or go here:
https://www.sound-smith.com/lookup/bo-cartridges/161
Maybe the record player belt also need replacement. Otherwise this record player and the pickup was a fine product in those days for many years ago. Even the inbuilt tape recorder.
I would go for the inbuild record player.
Good luck with this fine productπ
I've had expensive high end LP decks, and back in college when I sold gear routinely set up tables I was in no condition to afford. I think your best bet if you are serious about LPs and not just want to play a couple of them would be to use the B&O turntable and buy a decent record cleaning machine, something like a Record Doctor.
Here's the difference in the experience of LP:
B&O Approach. Buy system, make sure you have a good cartridge, plug cartridge into arm. Put on LP. Sit back and enjoy the music.
High End LP Approach. Buy turntable, maybe without an arm. Obsess over whether the arm you have or are thinking of is suited to the table. Figure out how to mount the table so if someone walks across the room the record won't skip. Then obsess over which cartridge is best matched to the mass and resonance of the arm you have, high compliance, low compliance, high mass, low mass, etc. Mount cartridge, using an appropriate protractor designed for this purpose to make sure stylus overhang is right and the cartridge is parallel with the headshell. Play music, adjust as required. Next, set vertical tracking angle (VTA) (If it's a high end table arm height will be adjustable). Do this by playing a section of an album, adjusting arm height, relisten, readjust, relisten, etc. until the sound "pops" into focus. Try and remember if the lower/higher position sounded better or not, obsess over whether you've chosen the right VTA. Next, get your phono preamp setup, a high end one will allow you to choose cartridge loading, resistance and capacitance. If the cartridge maker doesn't specify what's correct, repeat same experiments as with VTA to find the right settings. Now you're ready, put an album on, sit down, and worry that there might be a better combination of VTA, resistance, capacitance, stylus overhand, that sounds better. Go fiddle with turntable, listen, get up and fiddle some more. π
I think the reason a lot of "audiophiles" are so enamored of turntables is it is a focus for their obsessive compulsive disorder.
That sounds terrible. When does one actually get to enjoy the music? It seems like the individual who goes through all of the above, may continue to be focused on whether the music sounds as good as it can, and will likely only be listening for potential imperfections to address, rather than sitting back and enjoying the fruits of his or her labor -- the music itself! LOL
Go for the Beogram record player, - just put on the record and push "play"π
π 20 years ago I have to admit I was listening more for imperfections in the setup I had back then, instead of the music itself - switching cables and "carrying on"... I'm older and wiser now (hopefully) and I'm now looking to create a secluded spot downstairs to enjoy the MUSIC (and a break from nagging wife and kids π). Presence and true-to-life sound is what I'm hoping for...
I agree with ADU - just a couple of additions to make:-
Buy a new MMC cartridge from SoundSmith and bin the 30+ year old B&O one that came with the Beogram. Replace the drive belt (older radial Beograms) or have the turntable professionally serviced (newer tangential Beograms).
Kind regards, Steve.
The Beocenter 7000 is a fantastic device - the turntable is a lower end B&O deck but in fact has great suspension and a good arm. The deck is very like a BG1902, the first B&O deck I bought , and it is a great record player. The amplifier is probably the best 40W amplifier B&O made and the cassette mechanism is based on that of the Beocord 8000, which was the basis of B&O's best cassette player. To get better performance from B&O will be tricky. I ran my 1902 with a MMC6000 and loved it. I agree with Steve - upgrade what you have. It may need some electronics work as some components will be aging.
Jeffs reply hit home with me - audiophile record players are so much effort when at the end of the day you just want to listen to the music. Any decent B&O turntable allows you to do that. I have nearly been swayed back to non B&O record decks but luckily this site put me back on the right track! The other huge advantage with the B&O deck (for me anyway) is that when the record finishes the deck returns the arm and switches off - particularly useful if you are cooking or get distracted or something - or even fall asleep having had a few glasses of wine - not to mention some can be remote controlled.
True - after i had my stylus fixed in Germany I just listen to a lot of records (and actually buy some new records as well now). Press play and enjoy.
Register to access the forums, reference material, and exclusive member benefits β including our monthly prize draw.
