I have decided to keep the large tower speakers and the beosound 3000. it plays but the remote does not work and the volume only works with the aux cable plugged in.
Hey guys!
You may need to use the remote to set the appropriate option in the Beosound 3000 to enable the remote to control it. The user guide on the B and O web site should have instructions for doing this. In short, the 3000 needs to be set as audio master. Given all of the equipment you have it may not have been set as the audio master.
Razzlaw you are a Genius! This system sounds amazing!!!!!
https://www.ebay.com/itm/382774279303
The above link is for my Ebay listing if this is not allowed please remove.
