Hello all
I wonder if you could help me please, I live in France and I am having problems sourcing the following:
I need Bulbs or Holders and bulbs for a Beolab 1700 and a Beocenter 1400
I require a counterweight for a 1902 Turntable arm this is the oblong one that sits in the arm.
Motor required for a Beocord 5000 this for the tape deck transport mechanism (not the drawer motor)
Finally I require ( a blast from the past) a speed control adjuster for a Beogram 900 turntable, I believe this a Beogram 1000 deck correct me if I am wrong I think it also the same on a 1001 Deck)
This is the black adjuster that fits inside the Large Chrome speed control at the rear of the Deck which allows the speed of the turntable to be adjusted with the strobe on the platter.
At least it does if it is not seized ( i think this was the problem with mine and it made the D section round so it would not turn the centre spindle)
I am unsure if the black control removes from the Chrome Control (perhaps someone could advise)
Thank you
Joshua
