HDD Cloning gone wrong
Hello In group
I hve tried to upgrade my BM5 to SSD but sadley I haven´t payed attention to the windows shut down proceriure. so I just remowed power and then tryed to clone the HDD liked posted in other threds in this forum.
and the SSD diten´t work as planed 🙁 okay no problem just put the orig. hdd back in BM5 but No.
now i struggel with "windows root system32 hal.dll" fault
and i have tryed with the recovery start up but with no luck
Have I destryed the system or how can i repair without have the orig. software
and other question if I by a new marster unit will it connect to the display unit?
BR newbee in beo hifi
Jakob Jensen
So the BM5 is failing during boot, and not coming up at at all... and recovery mode boot (from windows boot menu) also doesn't work?
If both of the above are true, then I don't know how to help you 🙁
You need B&O Service tool for Beomaster 5. To fix your HDD in BM5.
/*Michael
Hello again
Now a have a contact that can boot my BM 5 and I got the right disk Crucial MX100, next question is Should I update the firmware on the SSD disk or laeve it as it is?
Br Jakob Jensen
