Hallo, Olli,
also wenn es kein Defekt ist (was ich aber befürchte), dann kann es sich um folgenden Deaktivierungsmodus der Glastüren handeln (aus dem Servicemanual). Wenn Du das ganze Manual willst, bitte PN an mich mit der Email (hier kann man, soweit ich das sehe, keine Dateien anhängen),
Viele Grüße, Andreas
Glass doors lock
When the glass doors are locked it is not possible to open them by magic open.
The glass doors can only be locked if the product is in St. by, the glass doors are
closed and only by remote control.
Press
SHIFT 9 0 3 6 9
with no more than 2 sec. between the individual entering.
The display shows "LOCKED".
To unlock the glass doors press
SHIFT 9 0 3 6 9
The display shows "UNLOCKED".
The function will be remembered in NVRAM after disconnecting from mains.
From TM01 to TM09.
- Wait 20 - 30 sec. after connecting to mains.
- By keyboard from St.by mode: Press
Display 0 2 5 8 RADIO
with no more than 2 sec. between the individual entering. Then key in the TM no.
- By remote control from St.by (can only be done if the product is not in option 0):
- Press
SHIFT 9 0 2 5 8
with no more than 2 sec. between the individual entering. Then key in TM no.
