Getting Beosystem 5500 components working
Sure....although I didn't make a list.
On the Beomaster 5500 I went through and replaced all of the electrolytic capacitors with new ones. I restore quite a few B&O components so I already had most of the replacement capacitors already. When I don't have the correct replacement value I look up a new one and typically order one from Mouser, Newark or Digikey.  I always try Mouser first because they are located pretty near me so I can get the parts very quickly.
When changing the electrolytic type capacitors I match the capacitance value and the voltage rating.
On the Beocord 5500 I only replaced the belts with new ones from Martin.
On the Beogram CD 5500 I replaced just the belt at first.  Later the CD 5500 started having a problem with its power supply and would suddenly shut off.
I replaced the electrolytic capacitors in the power supply circuit and it has been working great ever since.
Hope that helps,
-sonavor
Sure it helps!
I just dove in deep and can use all relevant info.
I have the same setup except for the CD.
It is still not vey clear to me if there is a big difference between the CD 50 that I have here and the 5500 :-)
The Beomaster is working , I am sure that recapping it will be the rewarding thing to finish up the project.
What difference did it make when you did yours?
The Beocord is waiting its upgrade kit to be recapped , I found a complete cérat set at Audio High Store. I will order the belts as well.  Is Martin the best placed for that?
If things turn out as I hope I will be doing the Beogram soon as well.
Beo greetings,
Hugo
Hello,
Do you have an idea for the question I posed:
/forum/general-discussion-and-questions/cd-50-will-not-start-frontlights-disturbed
Thanks !
