That all looks very "RX 2" under there. I've had to do that "bend with a screwdriver" adjustment on at least one RX 2. Pain.
Getting Beosystem 5500 components working
Yes, the Beogram 5000 looks like it shares a service manual with the BG1800, 2000 and RX 2. I think I have the thing adjusted now. The platter to deck surface looks good and Martin had me check the motor pulley. I was able to pull up on it so it raised a little and I can feel a spring action pull it back down. After doing that I retested the turntable rotating and it looks like the belt is staying on track now.
If I remember right, my belt is running near the bottom of the under platter without the record platter attached. With the record platter attached the whole floating chassis goes down a couple of mm. and the belt will reach the correct track.
Printing machine technician
Rock and Roll music
Collecting Vinyl
Okay, I'll put the turntable through some tests tonight and see if the speed flutter problem is fixed.
john
You do remember right Søren. After listening to the Beogram 5000 again I am not hearing the flutter in the speed anymore. I pulled off the platter and I can see the belt travel is now raised a little so it isn't riding along the sub-platter lip.
John
Hello - looked at your array of 5500 system. I have two complete 5500 systems that are in daily use. I really prefer this system to the 6500 series as the sound from the 5500 equipment is much, much better. I have a pair of Redline 60.2 speakers linked on one set and a pair of Penta (Passive) linked on the other - both sound terrific. I have three 5500 Beocords, two linked to one 5500 system. It is really good that the 5500 CD drawer comes out the right whereas the Becords open for cassette insertion on the left. Happy listening.😁
Prof D (Belfast)
Here is the restored system so far. It looks nice on my SC60 cabinet and with a pair of RL140 speakers.
I recently acquired an Attyca 1 cabinet for my Beosystem 5500. It all goes together better than with the SC60 cabinet. I will move my SC60 to another room where I will use it with its intended system components - Beomaster 6000, Beocord 8004 (or maybe a 9000) and a Beogram 8002.
I lucked into the RL cables actually. A couple of years ago there was an Ebay seller that advertised a complete 4500 system with two RL60.2 speakers. The price was really low so I bought it. When the boxes arrived, to my surprise, there were the cables. They hadn't been mentioned or displayed in the advertisement. Sometimes things just fall into place 🙂. Naturally I was overjoyed with the windfall.
Hello,
Can you explain which parts you renewed please?
TIA
Hugo
