I inherited a Beomaster 5500, Beogram 5500 and a CD 7000 and two big Penta speakers. I've got everything hooked up except the phono because the MMC1 cartridge is there but the stylus is missing. I want to hook up the FM tuner antenna but it looks like I need need a male RCA type jack with an FM connector on the end. It's such a tight spot it seems as though it has to be a right angle plug of some sort. Has anyone else had to put this together? Thank you Bill
FM antenna plug on Beomaster 5500
what you will need is a female PAL adapter to connect to the BM5500. You can buy dipole antennas with female PAL that work without the 90 degree adapter. If you already have a good antenna that you want to continue using that uses an F type connector with a male end, you can also get 90 degree female F to female PAL. These are pretty common.
Bill
