Expanding on my BG4000
Hi all,
I moved to a new place and looking to switch things up a bit. My current set up is a Beogram 4000/Macintosh MA 230 amp/Dynaco A25 speakers. it sounds great.
however I'm looking to go all B&O.
should I go with a Beomaster 3000-2 or 4400? I love the look of the 3000 and it matches the Beogram really well. But probably not enough power for most speakers.
the option on speakers I have is Beovox 1200 (not the book shelf)  or 5700. I just need enough sound to fill a small living room, I live in a 800 sq ft 1 bedroom apt. I do like my bass though, the A25's have been fantastic.
let me know what you guys think. I want to go minimalist but not compromise on sound too much.
thanks!!!!
Have you considered the
Thanks for responding. The Beolab 5000 with the tuner  looks amazing but I have no idea where I'd be able to track one down. Let me l ow if you hear of anything.
Would the Beomaster 3000-2 be able to power the 5700 speakers? Seems like the Beolab 5000 would have no problem. Correct?
Thanks in advance :)
Beolab 5000 for me as well.
The best, period.
If you are located in Europe I don't think they are too difficult to find. There is a Beolab 5000 link right now that is located in Sweden but requires a repair. To get a fully restored and working Beolab/Beomaster system you should check with Beoworld member Martin (link) and Frede (
The Beolab 5000 is a superb piece of equipment and built to the highest standard. The 4400 sounds better as it is 10 years younger just at a time when transistor amplifiers were improving. Having said that, I use my 5000 more than anything else! I you want the very best 5000, see Frede. He built mine and can supply a perfect tested 5000 system which will last years. because these are devices made at a component level, they can be restored and in fact made better than new. Frede can also do a 4400 for you if that is more your thing. If you have the opportunity, pick it up in person - you can visit Struer at the same time which is well worth a visit. The highlight is definitely Veno though!
The 5000 seems to be sold by a forum member Tamtapir, so he might have the details on the kind of defect it has.
thanks
//G
