Excerpts from the passing week
"Hi Martin,
I bought belts from Portugal, my Beocord 5000 worked fine for a few hours, now it stops intermittently and it seems to get worse and worse."
"Hi Martin, Can you help me? I fitted new belts in my Beogram 5005, got them off Ebay from a seller in Portugal. The platter motor emits an annoying screeching sound that wasn't there before. Did I do something wrong?"
"Hi Martin,
I recently was lucky and got myself a mint condition Beocord 2000 cassettedeck, I got it cheap because it was in need of new belts and a cleaning.
Now it runs but with with a huge amount of wow, I can actually see the tape spools speed up and slow down with the naked eye. The cooling fin at the back gets very warm, is this normal?
Can't be the belts, I think. They are all new from Portugal. If I send it over to you would you care to take a look at it?"
"Hi Martin,
Not sure, if you can help me.
I bought new belts for my Beogram 3300 on Ebay. It ran fine for a couple of days, now it won't start at all.
I can see the motor tries to rotate, but it seems to be locked. The motor pulley wiggles back and forth when I push it manually and it can only be rotated in the most upright position. I think this is wrong?"
Me: "Let me take a wild guess - you bought from a seller in Portugal?"
Owner: "Yes, - do you know him?"
Me: "Sort of..."
It's a free world. The belts are comfortably cheap and unfortunately also plentyful, it seems,
- but my heart cries.
For my first Beosystem 5000 I bought belts from the bespoken seller for the Beogram 5000, Beocord 5000 and Beogram CD50. They are all still operating.
But this time, for the second system, I ordered belts from you instead. It´s not even that much more, than from the seller in Portugal. It must be lack of knowledge, that people are buying them of Ebay. It was for me; I´ve learned since.
I would pin this to the top of the forum - one would not buy cheap tyres for a Bentley, why buy cheap fake parts for B&O?
I got a wrong belt fitted on the tape deck of my BC9500 in a B&O "sepcialized" workshop here in Germany.
Fortunately, with the informations and the right parts from Martin, I could safe my tape deck!
So I did not try to safe mony, I just relied on the wrong "expert"!
Wolfgang
Have a nice day
Maybe you can advise / help to buy the right belts for my Beocord 2000 reel to reel tape recorder?
Vytautas
For the cassettedeck Beocord 2000
Thanks for the fast response.
Just ... What to do?
These are at least as appropriate:
https://www.ebay.com/itm/303554414116
Should I try to construct from hydraulic sealing components? .... :(
Vytautas
Vytautas
Vytautas
Vytautas
