You can trust the kit contents.
Some caps were deliberately chosen because of the positions they work in.
F.e. there are places where "very non-" low-ESR caps are needed and some of the "trending" brands simply can't supply suitable components for this.
Anyway, I'm not sure I would choose a Beomaster 2400 as the source when evaluating or selecting speaker capacitors.
It's a wonderful receiver in its own right, and definitely one of my own favorites, but it was never spec'ed very
high and, surely, the Beomaster will be the weakest link in the Beomaster 2400-Beovox S45 setup in any case.
As said, the original caps were of a very high quality. Roederstein capacitors were actually some of the better ones on
the market back then.
Where almost all of the well-known plastic-housed cylindrical ROE ones are bad or at least marginal by now, particularly the
red and orange ones (with the older grey ones curiously being slightly better - but still not good anymore),
the matt grey and golden bipolar ones that B&Os used heavily for their speakers, proved to last better.
Some are still surprisingly fine, which may be the case in your speakers, but most will definitely need attention after 30-40+ years, which should come as less of a surprise.
Generally, when checking the condition of a capacitor; Capacitance and ESR meters are all nice and fine, but check the leakage too. That's where f.e. the old wax-paper capacitors fall through and what makes them fail in circuit rather than lack of capacitance.
I agree on keeping the vintage. If you want modern sound and feel, buy something modern.
I also still would recommend electrolytics in speakers where circuits were designed for electrolytics.
Monacor is a joker. Sometimes you will get very good quality, other times.. well.. not so good quality. Even if not always cheap, but expensive doesn't always mean better.
You won't find Monacor caps in my drawer.
Many of the capacitors I use for restoration and repair jobs and also in the speaker capacitor kits I provide are produced specifically to get as close as possible to the specs of the original caps (when they were new).
Most owners hear a distinct and clear difference when replacing old with new. And even if the original caps are still
found good, they are going to fail sooner rather than later, and new capacitors would be the better solution.
Certainly if you already have the old ones out.
But if you feel your speakers are still playing fine with the original caps, you are of course free to leave them as-is.
The price of original B&O rabbit ears antennas are often higher than that of the receiver they will be connected to.
I have seen them sold for more than 300 euros, so the one you showed me could be a bargain.
Sorry, I don' t have any.
