EDIT: Beogram 4002: speed problem at 45rpm after new belt (Dutch)
EDIT: Okay guys, even with manuals and technical schedules I can't get the problem solved.This is beyond or above my knowledge. If anyone knows a good Beogram specialist in Amsterdam (or surroundings) I would like to get his or her name. Thanks in advance, kind regards, Martijn
Dear people of the forum,
As my Beogram 4002 started to slow down in rpm I thought a new belt would help. But strange enough it seems even slower now at 45RPM. Playing at 33RPM seems okay.
Is anyone familiar with this problem? Answers are welcome, also in my native language Dutch ;-)
Martijn
Have you tried to adjust the speed potentiometer for the 45rpm speed? its located on the circuit board inside?
Craig
Thanks for your answer Craig. I'll Google (or Youtube) a bit to be sure where this potentiometer exactly is, but thanks for this tip!
Regards,
Martijn
Become a silver member and you will have access to the service manuals to help you 😉
The new belt is tighter.
Either the motor needs a very thorough service or the new belt has wrong elasticity and/or size and will eventully cause permanent damage to the motor bearings (if bought off Ebay this is very likely).
Thanks for your answers guys! In the meanwhile the platter is spinning again, but I the 45RPM speed problem maintains. My own manual is somewhere in a box in a depot, so maybe I should start searching it ;-)
Hi Martijn
How are you this not an answer for your question, rather I need you expertise on a schematic written in Dutch kindly translate it to English. I hope you got an answer if not good luck.
Thanks in advance
I ca try, just sent me what you have...
Regards
Afgezien van de potmeters is het relais een zwak punt.
Dat relais schakelt op een bijzondere wijze en zijn niet nieuw meer te krijgen. Een vervanger is er niet voor.
Ik heb een alternatief relais samengesteld uit een klein SMD relais op een converterboardje. Dat komt dan op de plaats van het originele relais. Dat werkt als een speer. Het is niet gegarandeerd dat het de oplossing is, want ik kan uiteraard op afstand ook niet zien wat er inmiddels mee gebeurd is.
Maar als je niet een goede snaar hebt besteld en, zoals Dillen al aangeeft, er eentje is die via eBay is gekocht, dan heb je waarschijnlijk een veel te strakke snaar waardoor de tafel niet op snelheid kan komen.
De motor kan ook nog de oorzaak zijn en soms moet deze uit elkaar.
