I just performed this manoueuvre on my Ouverture. Only a very small portion of the upper guides are visible but it actually seems like they are not really "used" the same way as the lower ones. I believe that with the doors attached, the weight is on the lower guides and the upper ones are not actually touching the plastic guides with any real force.
I cleaned the lower ones with a Q-tip and then sprayed some silicone lubricant spray on a new Q-tip and dragged it along the slanted edge where the door holder rests and moved them manually back and forth a few times.
I found that some noise came from what must have been misaligned doors even though they looked like they were positioned correctly. I adjusted the door holders several times before they moved perfectly smooth without hitting eachother when reaching the closed position.
Can you describe in what way it does not feel smooth? Is there a noise during the entire movement or does it sound like it it hitting some dirt along the way?
