Deezer on Beoremote One BT (non N & A)
Setup:
Beosound Core
Beolab 50
Beoremote One BT
I am trying to get my Beoremotre one to show the deezer option when I press "music", but I only get TuneIn and Join.
It seems like I can change all options until I pair the BR and Core then the BR get's locked and I can't even make "my Buttons".
I have tried to do a factory reset of both Core and BR but nothing helps. Should I not be able to control deezer from the BR?
When I start music from the beo app from Deezer I can forward and pause/start music with the BR.
I was hoping that the BR could be a simple way to start music but right now it can only be used for TuneIn - this means I still have to have a iPad/phone at hand.
Hope someone can help.
thank you.
It's a valid combination and should work.
I do have had similar situation in the past. Not sure what the cure was. The BR1 updates itself after you put the set in standby. Check updates for the Core.
Do you get your TuneIn presets on your BR1? It should be synchronized after you paired them.
hi,
both the Core and BR1 have been updated. Tunein works perfect.
I don't have a BV to use with the BR1 but plan to use it with the LG C9 when I get that one next week.
any input is welcome.
found out that if I start a playlist on Deezer via the BEOAPP and then press and hold down the mybutton to "code" it. the my button will start deezer and that playlist, but still no deezer in the menu when I press "music"....
I have the exact same setup, Core, BL50, and BR1. I set mine up some time ago so I do not remember exactly how I did it. If I push the music button, it displays options of join, tune in, and music. Selecting music starts Deezer.
Same situation, when I press MUSIC -> Music on the BR1 it plays Deezer.
Question:
Is it possible to save a Deezer Playlist / Deezer Mix to a myBotton?
So that for example I could link myButton 1 to Deezer Paylist A, myButton 2 to Deezer Playlist B, etc.?
Comment:
When I save TuneIn on a myButton, BR1 saves not only TuneIn it also saves the related radio station. There should be something similar (more detailed information) possible with Deezer !?!
