Cool product sites..
If you want contemporary furniture I suggest you try mac&mac interiors. They sell a lot of quality furniture from top Italian makers. I recently bought a Calligaris sideboard from them - good service.
I've only ever bought repro Eames and Le Corbusier but would recommend Vita Interiors in Bath - very helpful. Interior Addict in London is OK for some stuff but make sure you look at it before you buy - not all Chinese copies are the same!
I you are looking iconic designs Knoll has a great selection of tables. A close second is Cassina. Just look at their websites. And depending on your taste you may like http://www.fontanaarte.com/furniture/furniture-f/tavolo-con-ruote/ from Fontana Arte, or Zanotta. A great source to search is the website designaddict.com.
cheers...
9 LEE wrote:
Does anyone have any suggestions for a website which just sells well designed, higher-end products?
This is one of the best, Lee:
have a look at this site
http://barrique.sanpatrignano.org/en/catalogue
Ralf
or even
